Peter is right, he accurately answered a direct control system question.
This is a CONTROL SYSTEM site no matter what the good folks running it have for a name.
Peter never tried to advertise in any sense of the word, and is the ultimate authority to respond to legitimate question asked by another member.
Please don't stifle him.
Now, back to the subject at hand, I have a related question, which I could easily research elsewhere, but I would like it to be part of the thread and get it back on track.
Does the CompactLogix have ladder based motion? Servo Cards? If yes, Sercos/Analog/Both? I haven't gotten to work with A/B motion since the S-Class/1394 days, and may have misspoke ealier by jumping on the c-logix bandwagon.
CompactLogix motion: Is it a full motion command set? Electronic camming? If so, then it should not be too hard to write the logic that could turn 3 linear axes and a turntable into a rectangle pattern stitcher with rounded corners, and let the HMI edit the general parameters from which the motion profile can be calculated using the mechanics of the axes.
Whatever controller he chooses will either need to control the speed of the "stitcher" or be capable of picking up at the very least a velocity input from it. Ideally I would htink you'd want position feedback from the stitcher at least so that stitch length can be maintained (and therefore adjustable) throughout the whole pattern. That would give you the ulitmate pattern flexibility.
My only motion application experiences with coordinated motion was done with A/B IMC S-Class/1394 systems using GML Commander running 2 to 6 axes, and it was quite extensive using most every feature available. I can tell from just reading that much of that knowledge translates into C-Logix.
On the other hand...
If there is little I/O on the machine, it may be much less painful, though, to just use a motion controller, HMI, and no PLC...
Peter, (another machinery control question, not a price list request
What are the I/O capabilites of some of the Delta controllers?
And is my previous statement worth expanding on? What I am getting at is, are Delta controllers used often to handle a whole machine?
PiEaCe!
