AB VPL Servo motor and IEC flange
dginbuffalo
Dec 2010
Buffalo,NY
630
Hello all- we have a project where we wanted to use an AB Servo and VPL motor. The old linear table has a nema 23 mount that attached to the nema 23 servo motor. the new motor spec'd is a VPL motor that uses an IEC metric, flange w/free mounting holes (type FF). Any ideas on adapting?? Why does it seem AB's servo motors are all IEC and the linear tables all have nema flange mounts?
Hello gentlemen, I have Allen Bradley Servo drive(P/N: 2198-H040-ERS) in stock. However, the servo motor should be Allen Bradley VPL-B1003F...
4,118
Ahoy hoy. I have used a number of K5500/VPL systems over the last couple of years, but this is starting to really annoy me. I have had to...
3,976
Hi, I'm working on Mitsubishi MR-J5-70A amplifier, and need some advice on selecting fuse size. Main power is 1ph 240VAC, and in the manual, it...
91
Good morning, We've had an issue with a couple of servo valves and was wondering if anyone had seen anything similar. After a drop in pressure...
117
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
107
