ABB 07CR41 PLC Backup with AC31GRAF
riyajahamad
Jun 2002
Pune-India
133
Dear Experts,
One of my client want me to take backup of ABB 07CR41 PLC.
I never worked on ABB, but having command on Siemens, Allenbradly, Mitsubishi, Messung PLC's programming.
I got AC31GRAF software but I don't understand how to go ahead, I read software manual but I am not clear.
It will be helpfull if someone guide me.
Thanks in advance.
Riyaz
Thanks macs_plc for reply.
Are you worked on these PLC's/software? It will be highly appreciated if you give your cell number.
I am not uploading project from PLC, making preparation as Company where is PLC is far away, I am planning to go their, with well prepared.
It will helpful if some one tell me about cable required.
Is it simple serial cable or required some special one?
Thanks in advance.
Riyaz.
CAble required is rs232 if u r using a microplc...it depends upon the plc types......
Otherwise u can use AC1131 software -- it is for the same 07cr41 type PLC more advanced and user friendly than AC31graf...anyway its up to u
Try working on that ac31graf sofware using any simulation driver...
so it will b usefull while ur client
My Mobile No. is 0091 97894 27977...
you can upload the backup using AC31GRAF software in CR41 but it will come only in statement text. open the AC31GRAF software and click options - upload application, give a name and select central unit as 40 series. it will take 5 minutes to upload.
use 07SK50 cable to communicate.
kindly reply..
Dear Experts,
Thanks in advance.
sasmita[/quote]
Hi all, i need help with my PLC Project. It sounds like a stupid question, but i have to make a lamp light up, when i push a button. Both dots...
1,619
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
108
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
158
Hi hoping someone can assist me with current issue I am experiencing with an ABB drive. Problem I’m experiencing is a ABB drive supply a large...
219
Hello all, I have an ABB PLC (PM573) and it has without MC card. I need to take backup from PLC to PC (in automation builder v2.7 ). My...
456
