ABB Freelance importing variables?
Lord Farquaad
Feb 2015
Noord Holland
35
Never worked on ABB Freelance before, and after this, hope to never again.o_O Hope someone here have worked on/with this spawn of the devil.
I am using Freelance 2016 SP1 [10.3.9142]. I am trying to import Variables with the associated "Location" attached to it. When I Export out of Freelance Engineering, the associated CSV file have the following columns populated. Name/Comment/Type/Res./X/Object/Location/P. When I then delete those variables inside the Variables(For test purposes), and take that same .csv file for import, the Location column is blank. Variable locations not imported.
So, if I create an new .csv file with all my variables (8000 in total), the Location is not imported. This forces me to go and do each one manually. 8000 variables is gonna take some time, don't you agree?
I contacted our local ABB specialists and they confirmed it does the same on their side, but have no solution for this "bug". They did suggest I use the Bulk Data Manager, but this also turned out to be a waste. Bulk Data Manager does not export the Location with Variables.
Please would someone help me do bulk importing of data. I can not believe it is not possible in ABB Freelance. This is a simple task in Siemens and Rockwell. There must be a way. What am I doing wrong?
Recently we have purchased the Rosemount 752 remote indicator to replace with new one, Capability file for that FF Device is unable to import with...
33
HI. I am using ABB Freelance 2016 sp1 software for programming PM 902F redundancy controllers. Here i need a logic for analog output open...
1,374
Hi guys, my boss and i are slowly planning to replace the control of our system for all the mixer, water counter, temp controler we have, mostly...
3,316
who have experience about abb freelane 800f, please help me to use it.
1,508
Hello Everybody I have been looking for information for setting up communication between: ABB Frelance controller PM783F and ABB Process Panel...
2,517
