Absolute Encoder Losing Position
Clevername
Oct 2009
NY
36
Hello All,
I'm using a Schneider ATV32 and absolute encoder for positioning a linear motion. "Sometimes" after a power cycle or estop I have to reset the 0 mark or offset of the encoder. Its weird because "Sometimes" it holds it value. Maybe noise as the P\S is fading?
I thought the whole point of an absolute was to make this unnecessary. I could put a homing routine to hit a prox switch in I suppose but it seems like I maybe missing something.
Should I be storing the offseted value somewhere just in case?
I don't know the physical system but couldn't be anything sliding. That way your system moves but your encoder does not
Nothing is slipping or moving. It just doesn't hold the value after a power cycle which defeats the point of the absolute encoder. Not sure why.
Hello. An absolute encoder on a rotary axis gives values in range -2147483648 to 2147483648. When value is > 2147483648 , the encoder value is...
20
2,308
I have 2 Absolute Encoders 8192 steps per Rev. (Model TR Electronic CEV65m-11003) These Encoders communicate to the PLC5-60 via Parallel push/pull...
1,519
Hi guys I am new to Encoders, so I have limited understanding of how to actually configure it, to the situation that I am in. Using this Absolute...
1,589
Hello to you all! I hope there is someone who can clarify some things to me..... Equipment used: TM PosInput1 (6ES7138-6BA00-0BA0) to read the...
1,271
How to connect the absolute encoder(12 bit resolution) to Hsc module of Slc500 Plc and get raw-data to my ladder logic? Please give me example...
2,714
