Absolute encoder SSI interface and Grey Code
See if this helps http://en.wikipedia.org/wiki/Grey_code
To make it simple Grey code just changes one position at a time.
In binary if you go from 1 (001) to 2 (010) you have to change the 2nd digit to 1 and the end digit to 0.
In grey code only one bit position changes 1 (001) to 2 (011), all that changes is the middle bit.
RSDoran's answer is absolutely correct but he did not explain the reason for using grey code. The answer is simple if you look at his examples. In the first instance (binary) you will see that as the code changes from 1 to 2 the encoder must turn off bit 0 and turn on bit 1. If bit 0 turns off slightly before bit 1 turns on then the output briefly becomes 0. If bit 1 turns on slightly before bit 0 turns off then it briefly becomes 3. With larger numbers these errors can become huge. Grey code only requires one bit to change for each increment so the errors are eliminated.
Andybr
I'm being asked to bid a control system using Siemens S7-1500 controllers, which I don't have any experience with. The digital, analog, and...
2,665
I have an absolute encoder that is connected via SSI to a computer. Has anyone seen a PC card that transmits SSI so that I can create an...
3,373
Hi Guys I am using SICK absolute encoder ATM 60 with an SSI to Parallel Converter (AD-SSIG-PA) to connect to a Mitsubishi Q02HPLC. The set up...
6,368
Good evning everyone, i need some help, dont know what to do!! Yesterday we were going to do some changes on a machine at my work, we tried it...
7,328
Hello. An absolute encoder on a rotary axis gives values in range -2147483648 to 2147483648. When value is > 2147483648 , the encoder value is...
20
2,307
