AC torque motors: Triacs and Variable Transformers
Tenbaum
Jun 2006
minnesota
Hi Guys,
I have done some research on the AC Torque Motor control problem (I need to vary the voltage via a controller that can also interface with a PLC). Some mentioned using a triac and I was wondering if someone had some information about that. Also I know you can use a variable transformer but I have only seen variable transformers that are controlled with a manual knob and don't connect to PLCs. Does anyone have an suggestions? Thanks a lot.
Tenbaum
Yes, look into the Watlow Power Controllers I linked in the first post about this. They use back to back SCR's (essentially a triac) in order to vary the output voltage by phase controlling the SCR firing time. Still 60Hz, but 0 to (Vin).
Also, you can check Oriental Motors controllers, or find a brake controller that can be configured for a 0 to (Vin) output. At one time, I believe Saftronics made one.
I have a question regarding some calculations I'm doing... I find that most of our motors are around 1/2HP, so for some applications we may...
2,306
I've got a quick question: A normal motor's HP vs. Freq graph is a straight line starting at zero and going to full load as freq goes from 0-60...
2,534
I realize this is not about PLCs, but there have been a lot of questions answered on here about motors so I thought I would place this here. What...
15,911
Hello everybody, I understand that DC motor adjusts the speed by increasing/decreasing Av.But if the load torque increases, Av should be...
10,406
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
105
