access path of pc access!!
subnet
Jun 2006
seoul
I am tring to run WinCC with PC access but it would not work!!
I think i have written wrong access path to address PC access item.
What is access path to address PC access item?
is it "MicroWin.plc_1"??
please help!!
I have found it my self!! does not need to put access path!!
just add item with OPC item manager!!
it worked!!
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
182
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
89
I have to provide remote access and control to a touch screen. I was thinking about using Weintek and the Weincloud. Does anyone know if this is...
609
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
75
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
345
