Access to CompactLogix L45 Processor
JiNCs
Jul 2007
South Carolina, USA
66
Hey Folks,
I am trying to come up to speed with Ethernet comms for control of a servo drive using a CompactLogix L45 processor. I have RSLogix 5000 software loaded on my laptop but cannot connect to the processor. I get the message that the “Controller type is not supported.”
The version of Logix 5000 I am using says in starting that it has versions 13.04, 15.02, 16.00 and 17.00 installed.
What do I need to do to get this solved.
JiNCs
Can you see the processor in RSLinx? More specifically, can you see the icon associated with it, or do you get a yellow question mark?
You may simply be missing the EDS file for that processor in RSLinx...
Can you connect with the CPU using a serial link and check the ethernet parameters?
Seems the thing to do is open the ver16 file with ver16/17 and save as ver17 so it can be opened by a ver17 . . . according to Rockwell.
JiNCs
No I cannot see the processor, backplane or icon. I see the Ethernet ENBT module used in the system and there is a + next to it but when expanded it shows nothing!!!
Hi all, For those that do, thanks for taking the time to read my post. I have some experience, mainly self taught with Allen Bradley SLC &...
2,549
PowerFlex 525 - can you access the parameters from a MicroLogix 1400 & CompactLogix Good Morning , I have a separate stand alone machine...
3,337
Hi Guys, I've been working on and off on a new Feed blending plant for a while now. The system has been batching away now for 6 or 7 months...
4,469
Hi, does someone know if up-to-date 'CompactLogix' controllers support ReadTag/WriteTag services via unconnected, explicit messaging (SendRRData...
4,347
Hi, I have a CompactLogix PLC and I am trying to access the values of an array of number which has 100 elements, but all I get is the last...
3,390
