access USB port on PLC or VFD via ethernet
ThomasGruetter
Jan 2010
Florida
63
I have a Hitachi WJ-200 VFD and an Idec PLC, both with an USB port for programming. We have a remote access device that only has ethernet ports.
Is there a converter to go from ethernet to the USB port on the drive or PLC?
I'm using the 5 port version, Software has a USB dongle and the Hardware takes a USB connection. So that device is local and has the key and the connection to the hardware.
I can connect over the WAN when needed and my laptop will see both the Sentinal Key and hardware.
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
186
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
93
I have to provide remote access and control to a touch screen. I was thinking about using Weintek and the Weincloud. Does anyone know if this is...
615
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
76
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
348
