Access VBA into RSView32 VBA
Bob O
May 2003
1,873
Is it possible?
I have created some reporting in Access and would like to use the VBA code from Access and install and run it in RSView32. I don't want to buy x number of seats for Access for our customer computers. Any help would be appreciated. I know very little about VBA.
Thanks,
Bob O.
You might do better to look into using Crystal Reports or something similar. I believe CR allows free distribution of report templates and run-time dll's. If the data you're reporting on is coming from RSView logs, then it'll be in dBase format - no need for Access.
Bob O,
RSView does have a Visual Basic editor built in. To get to it from the Project window, go to "Logic & Control", then click on "Visual Basic Editor." Try copying your Access VBA code and pasting into the RSView VBA editor. Then you will need to make a few variable changes and do some Dimension and Print statements and so on to get it to run.
Bob.
There are several levels at which you can address these kinds of requirements that aren't part of the native RSView fucntion set:
1. Use the RSView command line, or create macros.
2. Use the VBA script editor that is built in.
3. Use the RSView Object model to create hooks to external applications.
4. Find or develop an ActiveX applet that does the job.
Actually Gerry's suggestion with Crystal Reports, if it meets your requirements, is the most straightfoward approach to advanced reporting within RSView.
Hey all, Simple question (and hopefully a simple answer), I have an object, example Polygon1, in a screen. I want to access the object's...
6,330
Hello, I have a problem I cannot solve. How can I access user defined data type tag member using VBA. I have written a short script that allow...
2,404
Hi all, I'm struggling to figure out how to automatically trigger reports in an Access 2007 db via a Boolean tag in Factory Talk View. We have...
2,541
I'm modifying an existing Interactx project that calls two different applications written years ago. The applications do not initialize on the...
1,459
I'm using RSView VBA to record the last parameter adjustments made for a given product in an MS Access data base. The Access table contains...
2,344
