AccessDB Lockup
dphilps
Mar 2010
TN
I am using the RSview32 VBA to write to a Access table. Works
great for me, however no one else can open it on the network.
Here is the code for opening and closing the DB.
Opening and writing is not a problem, for some reason i am
restricting for other users.
Any suggestions??
Set objConnection = CreateObject("ADODB.Connection")
objConnection.ConnectionString = strConnectionString
objConnection.Open
Set objCommand = CreateObject("ADODB.Command")
With objCommand
.ActiveConnection = objConnection
.CommandText = strSQL
End With
objCommand.Execute
Set objCommand = Nothing
objConnection.Close
Set objConnection = Nothing
Dump Access.
Install MSSQL Server, or at the very least MySQL.
MSSQL Server Express edition is free. MySQL is free, but can possibly require a license depending on usage.
Access is fine for holiday card mailing lists, and nothing else.
I can't much help then. Access is not a well-behaved back end for multiple user access. Check permissions and such, and make sure that your writes to the database close and destroy the connection as soon as possible.
Table locks will still be an issue, and result in loss of data though. If they just want Access for the front end, you can use links to SQL tables, but it sounds like that isn't going to work either.
Sorry. I have one system running with Access as a back end, and it is a penultimate disaster. I spend more time trying to protect those tables from corruption and ANY external access then I care to think about. I'm pushing hard here to scrap the whole system, and start over with something real, but it's too vital for production now.
I'm also planning on a call to Rockwell in the morning. Meanwhile, I'm here to see if anyone seen anything like this but i don't have much hope...
3,138
The Mixer came from China with a S7-200CN, 224XP CPU. 3 Chinese VFDs. V&T E5-H. Wired together with RS485, 2 wire. 9600, no parity. 3 different...
3,436
Good Afternoon, I'm working on a project that is receiving just under 100 bytes of serial data every 15-30 seconds. I have an NJ-1320 PLC for...
2,123
Is this possible? Recently on a machine connected to an InTouch SCADA, we have been losing comms from the DASABTcp driver, & to a certain extent...
27
9,025
Greetings, I have a CompactLogix 1769-L32E operating a water tube boiler. It is connected to an HMI and a SCADA LAN through a 4-port industrial...
5,081
