Omron NJ-1320 w/ SCU-22 Serial card Lockup
edpg1
Nov 2012
Ontario
19
Good Afternoon,
I'm working on a project that is receiving just under 100 bytes of serial data every 15-30 seconds.
I have an NJ-1320 PLC for SQL database communications, and an SCU-22 V2.1 the data comes in as a Comma Separated String, it then gets truncated with a "SubDelimiter" Function into a Custom Data Type. Then gets data added to it and sent to the SQL Database.
Problem is, after about 30-80 entries the Serial card stops receiving data, and requires the 24V to the PLC to be dropped and restarted.
I am using the SerialRcv instruction to receive the data.
Any suggestions as to what might be causing the card to "lockup"?
Thanks,
Have you had any luck with Omron tech. support? I am curious if they have any knowledge of this given it's a new(er) controller.
Is there a 'buffer' that is filling up?
I've got a call in with them.
Figured I'd check and see if anyone else has run into an issue like this.
I originally thought buffer issues.
But the function I am using, is supposed to clear the buffer after every read. Also the buffer would only be 255 bytes, at 100 bytes per entry, I should only get 2 entries then the buffer is full, as I stated in the OP I'm getting 30-80 entries.
I know I'm doing something wrong here, but for the life of me I can't get the Omron Designer Software to see the String Data in the NJ (Also...
1,541
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
145
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
63
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
102
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
256
