Acessing S7PLC 400 through DASSIDirect or DASS7
dguedez
Feb 2011
Austin
19
For those with experience with DASSIDirect, DASS7, and S7PLC-400's:
Hi, I'm new in dealing with Siemens hardware. My coworker has already configured the S7PLC-400 network's configuration using step 7. I also have step 7 v5.5 installed on my laptop and able to view the network properties of the PLC. With that being said,
I'm trying to connect to a PLC7-400 using either DASSIDirect and/or DASS7, whichever is quicker and easier to setup. I'm using a laptop with an ethernet device wired to a Siemens CP443-1 Advanced. The Siemens CP is on Slot 5 and the processor is on Slot 3, all on Rack 0. I am able to ping the S7PLC by going to CMD and typing ping <address of the plc> so I know I can see the PLC on the network.
In the SMC, for DASSIDirect I set the configurations under S7Cp as the following:
Network Address: <the address of the CP card>
LOCAL TSAP
Defaults 1.0
The DASSIDirect has been activated, and I keep getting the following in the Log Viewer:
DASPROTFAIL DASSIDIRECT Connection Aborted
REMOTE TSAP
Remote Rack: 0
Remote Slot: 3
Connection Resource: 5
Also, I've installed DASS7, I put "CP 443-1 Advanced" under the CP node type , but i don't know what to put for VFD, and I don't know what to put for "Connection" under the node type CON. Currently I have this server deactivated. Also, after reading the help file, I have some questions about using DASS7. Is it possible to use DASS7 by just using the ethernet device on my laptop to connect with the CP443-1 on the PLC? In other words, do i need a CP card for my laptop/desktop in order to use DASS7? If not, is having S7 installed enough for DASS7, or do i need to install additional siemens software before setting up DASS7.
here are some Screenshots:
http://img232.imageshack.us/img232/5092/s7cp.jpg
http://img513.imageshack.us/img513/4333/s7plcnetconfig2.jpg
http://img151.imageshack.us/img151/2953/smclog.jpg
I appreciate any help you can give me. Thank you.
Is there any wayout to access the database of ArchiveManager in Excel spreadsheet at specific intervals.....
1,522
Greetings, I had an issue with a RIO rack 2 and IFM I/O Link dropping on my network. I would loose connection for a second or 2 then they would...
55
I HAVE B&R POWEL PANEL 400 HMI. THE ISSUE IS HMI NOT BOOTING, DISPLY SHOWING CONTIUESLY (ATTEMPTING TO A BOOT HARD DRIVE....)
60
Hey all, first time poster here. I am wondering if anyone has tried using a Keyence SR-X300 barcode scanner to a Micrologix 1400. Keyence sent...
83
I have a micro1400 processor running two routines (transfer compression/compression molding press). Recipe parameters are stored from job to job...
79
