Add on Instructions - Studio5000
Sham
Sep 2019
Australia
152
hi all,
can you guys please explain the why we use AOIs? My understanding is that they can be used like templates, so we create them once, and keep reusing them as required. But what are the things we need to keep in mind? Like which parametres?
What is the role of parametres and tags in AOIs? How do we use one AOI for different inputs and outputs, where the logic stays same?
If someone can give a simple example too, that will be most helpful.
Thanks.
Think of it as an FB if you have done work with other platforms.
Say 20 motors with Start Stop and Indicator "Running".
Create an AOI with the Start/Stop logic and the indicator.
Re-Use the same code (AOI) for all 20 motors.
Just plug in the inputs and Outputs, the logic remains the same.
Hope makes sense.
Thanks.
Think about the AOI as an instruction like a timer [TON]. A TON uses different addresses but uses the same logic behind the scene to give you a time elapsed value for the address of the timer you specify.
In RSLogix5000 I am attempting to create an add-on instruction called "SWAP" which simply swaps the values of two integer tags. Here is what the...
1,967
Hello everyone, Currently I am translating my Siemens program (SCL) to Allen Bradley (ST) and i am having a little trouble using the Add-On...
1,524
Hi Everyone, I am working on project that the customer require no ADI. The standard project we have uses ADI everywhere. I am just wondering...
2,387
Hello everybody, From user manual "ControlLogix SIL2 System Configuration", SIL2 Add-on Instructions is required to configure SIL 2 PLC...
1,162
Hello, Can anyone please explain me concept of using Add On instructions in Rslogix5000 or in Studio5000? Why do we use them and for what? Thank...
3,082
