Adding a 700 drive in plc-5, replacing 1336
remullis
Oct 2012
Georgia
179
I currently have a 1336 hard wired drive that I would like to swap to a 700 using a Rio adpt. How do I go about configuring this in plc 5. We currently have some in operation but i can't seem to find exactly where in the UK config where you define groups, rack size etc. Thanks
get into the plc program.
select channel configuration and select channel 1a or 1b.
you can configure the port for remote I/o, remote I/o adapter, or dh+
the drive should be 1/2 rack in size.
if this is a new cable, you will need end resistors, I could be wrong on this.
I could be wrong on the size, but I don't think so.
if I am incorrect on any thing else, someone please correct me.
james
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
60
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
138
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
174
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
148
Hi Folks. I am gearing up to add a 2nd identical HMI to a project. This 2nd HMI will basically be an exact clone of the 1st one. The equipment...
266
