Adding additional memory?
02js4130
Jun 2014
Wales
38
I have encountered a situation where the PLC ( Micrologix 1500 LRP) has reached its memory limit, so i have done some research and found out that there is additional memory available in the form of a 1764-MM2,Perfect!
The problem comes when i try too find out how too address it using Rs Logix 500. e.g. do i add it as additional module in the controller properties? or is it a custom configuration?
I would like too do this so that i can continue programming in Rs Logix, and 'trick' program by thinking it has additional memory before i have purchased one.
Any help would be great!! Thanks in advance.
ahh ok i did wonder this when i was researching.
Is there any way of increasing the memory? or would i have too chance processors completely?
Hi guys, Is it possible to add additional shunt modules (braking resistors) to a 1394 system? We have one on the Z axis now, but the weight of...
1,397
I have (2) 1746 racks with a SLC5/04 and (8) I/O cards in each. When I attempt to add additional cards I get a fault and cannot see the 2nd rack...
3,136
Good Morning, Let me start by stating that I do not know a great deal about all the intricacies of ControlNet, but I have read and have been...
9,574
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
82
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
74
