adding connection to multistate pb
Tryingtolearn
Jul 2020
south australia
hi i am trying to use a multistate pb for forward and reverse in ftview 12 but cannot work out how to add both connections to the multistate please help me.
Thanks in advance
Never liked the multistate button personally.
There is just one tag connection associated with this button. Typically, this would be an integer type tag (SINT/INT/SINT).
You would configure each state to set that tag to a specific value. The values you choose are up to you.
I could set the first state (State 0) with a value of 1 and have a caption "Forward". Then have the next state with a value of 0 and a caption of "Off". Then for the next state have a value of 2 with a caption of "Reverse.
I would add another state with a value of 0 and the caption of "Off". You will get a warning having two states with the same value. But we do want this.
That way pressing the button it would go Off, FWD, Off, REV, Off, FWD, Off, REV, ...etc. Without that, it would go Off, FWD, REV, Off, FWD, REV, ...etc. This is because once it reaches the last state, it cycles back to the first state. So, just a suggestion.
Then in your PLC logic, examine that tag. When it has a value of one, trigger your forward state. When it has a two, trigger reverse. And if it is zero, stop.
If all you want is to select between Forward and Reverse with no Off setting, just use a Maintained push button.
OG
Hello. Looking to add an unspecified TCP Connection to a CPU317, but the system is telling me "no corresponding CP exists at current location."...
4,630
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
56
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
136
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
171
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
147
