If a 16 point discrete output Flex I/O was inserted between the controller and another discrete module, what major changes would need to be done?
I assume the slot ID would need to change for all other modules proceeding the newly inserted one, but would that cause issues with the already written tags in the logic?
Unfortunately the current layout in the control panel would not allow the module to be installed at the end which would make configuration easy.
