Adding IB16S to the IO configuration - Logix Designer v31
Byczy
Apr 2024
Warsaw
Hello,
Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration
Can i add something like GSD file to the Logix Designer or does this mean that i need at least v32 or higher to be able to use this card in my project, i am using v31 right now?
Thank you for your help.
So basically first I need to get V32 or higher then I have to install add on profile to make it work. Do i understand it correctly?
Become familiar with the Product Compatibility and download utility on Rockwells support page. You can enter the 1756-L82ES and 1756-IB16S modules and test compatibility. It will list the requisite firmware and versions that are supported with any caveats to lost functionality on less than fully supported.
You should note that 31 isn't fully supported on an L82. Most of 32 is retired or limited. 34 should really be the minimum for an L8x processor, IMO.
Hi, I need help adding a new interlock switch to an existing circuit. I have never done on the existing circuit. I did set it up on the...
302
Hi all I’m looking at adding a RFID card reader to comfort panel pro , how do you set the rfid up can you connect to existing users and password...
101
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
171
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
134
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
233
