Adding IP Camera to PV+7
robw53
Nov 2009
south yorks
515
Has anyone had any experience in setting up an IP camera to display on a PanelView Plus? I haven't purchased any hardware yet, and just thought I would see if it's been done successfully.
I was hoping to use something like a Swann camera rather than a Cognex style as these won't be cheap.
Regards
Rob
It depends on the way you access the camera. If it is through a browser then PanelView probably wont work as the browser has no java or other scripting capabilities. But if your camera comes with an Active X control it may work with the PanelView. All you can do is try it and see if PanelView will allow the Active X.
I found a RA KB 808536 that talks about accessing data/images for a temperature sensor camera that might be of some help.
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/808536
This applies to PanelView Plus 6 700 - 1500 and PanelView Plus 7 Performance terminals. Using ActiveX controls to launch web page access HTML 5 in Windows CE 6.0 with Zetakey web browser http://www.zetakey.com/download.php
I know it can be done because we have that exact setup on a couple of our lines. But I had nothing to do with the setup for it, so beyond knowing that it is possible, I can't help you.
Bubba.
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
90
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
80
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
151
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
178
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
153
