Adding managed switch with ring topology
electro89
Mar 2012
Canada
106
I'm planning on adding Moxa EDS-400a or 500a switches around a plant (configuration is shown in attached image). I'm thinking the wireless link (which has not yet been installed) will be blocked unless a line is broken and needs to use this path. I need to know if a) this will work using Moxa's TurboRing protocol and b) if there are any considerations on creating a wireless link
thanks
Why wireless? What is the distance between the two wireless points? How many pairs of fiber are between the backbone switches? If you want redundancy and you have more than a single pair in the fiber run, you can jumper one pair from first switch to the last switch. This would require jumpers at each fiber drops. This will give you the redundant ring, but the physical path could cause an issue if the entire fiber cable is cut. I have done this in several plants that had three pair fiber and several switches.
I have some wireless but not on anything critical or a backbone.
Hey everyone, currently I have a bunch of unmanaged switches around a plant. the 2 opposite ends of this line topology are at totally different...
2,631
Hi, I need help adding a new interlock switch to an existing circuit. I have never done on the existing circuit. I did set it up on the...
295
Hi all I’m looking at adding a RFID card reader to comfort panel pro , how do you set the rfid up can you connect to existing users and password...
100
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
171
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
131
