Adding programming access to DH-485 network
mr_b_at_work
Sep 2007
Scotland
Hi There
I currently have an installation which includes a PV700 connected to a SLC 5/03 using DH-485. The issue I have is that I cannot connect my laptop to the machine while it is running without breaking the connection to the HMI (not ideal).
One option I am looking at is replacing the SLC 5/03 with a 5/ 05 and utilising the ethernet connections.
Before I do this does anyone have any advice on how I could add laptop access to the existing DH-485 setup.
Many Thanks,
Craig
What physical connection is it between the PV+ and the SLC-5/03 ?
One of the DH485 isolators, 1747-AIC (old style) or 1761-NET-AIC (modern with RS232) might work, and give you a place to plug in a 1747-UIC to the network.
Yes, the connection is between an add on module on the PV (giving dh-485) straight to the slc5/03. I might add that the 232 connection on the SLC is used to talk to a remote PC so is not available.
Just to add...there is a DH+ socket beside the DH-485 one on the panel view...could this be utilised for access ? I have also attached a simple diagram of what exists.
All, I was wondering. How do you add a number to another number(say level input) only once, to keep it constant. Example: You have Num1, which...
2,612
Hello everyone, I am hoping I can get some help here. I have a machine that has a SLC5/04 with 33 program files, I am needing to add an...
6,288
Hi all I’m looking at adding a RFID card reader to comfort panel pro , how do you set the rfid up can you connect to existing users and password...
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
104
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
80
