Adding steps to a Panelview
Leukic
Oct 2018
Leesville
93
Good Morning/Afternoon everyone this is my first post as registered member but i have been searching for a few days with no luck.
So here is my problem and questions' I hope I can explain it thoroughly.
I have a A&B panelview 600 accompanied by a SlC04 processor in which I connect via a 1784-U2DHP cable.
I work in a brick plant and it has a Transfer trolley you can say that moves carts of bricks from one track to another. Think of it as a single lane road with 6 street only on the RIGHT side of the road it still stop at and offload the cart of bricks.
Now in the current program in the plc the PUSHER only pushes to the RIGHT 2 times to offload the cart of bricks. You can see on the Panel SS I took steps 15-18 complete these two pushes. And with these 2 pushes the carts of bricks are only about 8inches away from the safety light curtains (TOO CLOSE for me) Had multiple arms and Light curtains being torn up from hitting the carts when it is told to move.
Now in the modified program I ADDED the two rungs circled in RED to make the PUSHER push to the RIGHT 1 more time to PUSH the carts FARTHER away.
The MOV files are the steps at which the PV is in and it displays on the screen.
IF by JUST changing the program will the steps in the PV be displayed to account for the changes I made ie (insted of steps 15-18 it is now 15-20)
Or do I have to go into the PV and adjust steps in there according to match the program?
I hope I explained it where the forum can understand if not please let me know. Thanks
J
Only the picture of your ladder came through, the two other picture doesn't show up correctly.
I assume you are talking about the old AB Panelview that is programmed with Panelbulder 32?
Most likely the steps display is done with either a multi-state indicator or a bunch of "visible when X=Y" objects. Yes, you will most likely have to use Panelbuilder to change the display by adding the new steps.
I am not sure why the picture of the actual PV screen I took is not showing up as it is also a png file just like the ladder rung.
And yes I have panel builder 32. That was exactly what i was worried about as I have not dabble in the PB32 at all. Thank you for the fast reply Harryting
If you need more help, post the exact model # of the panelview and the PLC to PV connection scheme. Also, do you have an offline copy of the PV file?
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
57
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
136
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
172
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
148
Hi Folks. I am gearing up to add a 2nd identical HMI to a project. This 2nd HMI will basically be an exact clone of the 1st one. The equipment...
263
