PeterW
S7Guy said:Seriously, I know hundreds. Maybe you are working at the wrong plants.
Same here..
Like any PLC they needed training though.
dahnuguy said:All good points.
And yes after you go through it the first couple of times, it is not much of an issue. AFTER............not during. During the first couple of times it is not pleasant.
In the textile world it has to be simple, in any manufacturing in the south east USA, it has to be simple.
Why would it be so unthinkable for the editor to take 10 as 10 dec? It is the default for humans.
How many times have you asked for 10 bolts at the hardware store and the guy gives you 16 or 8 because you left the base 10 out?
As such I want a car that I do not ned training to drive and I think for 4000 USD an editor should be able to take 10+3.6+1200 and not choke because one is a DWORD real and one is a WORD INT and one is a DWORD INT.
And now explain what is the benefit of turning off data type checking if it allows you to make more mistakes more easily.
dahnuguy said:Really? Why in the southeast? (cuz thats where I am)Are you saying they are stupid or something? (nope)Hundreds of companies have relocated to the southeast over the years (BMW in SC, Daimler-Benz in AL, among many others and none of them started here). Their processes are not simple by any means, and they do just fine. (and I bet they brought their team of engineers with them to support said process)I think you are making some bad assumptions. (nope)
He would always try to explain it to me like I was the one who didn't get it. Sorta like some of the people here.
Why is it so difficult to accept that S7 is not well documented or as easy to learn as all other PLC programs?
Some people actually like using complex systems to maintain a high ego boost. Never got that. I don't need a Casio programable graphing calculator to do Algebra or Trig. No one does. But there is that small group that will. Just because.
If any of you guys ever write a PLC prog in STL for a textile company your in for a surprise.
dahnuguy said:Your code will be much more streamlined because you don't have to do trivial type conversions when they aren't necessary. STL take it even further to the next level. For instance, you can try this one yourself: Convert an analog input, scale it, multiply it by 34.67, and display it as an INT. Do it with type checking on, type checking off, and then in STL.
This I will do ....................sounds like an educational exercise, thanks.
I don't always want the answer but a shove in the right direction is nice.
dahnuguy said:I never saw motion on any textile machines..........dye house and yarn, weaving, drying, warping, carding, transport, spinning ummm prolly more, but I am sure I didn't see it all.
PeterW said:I've gone the other way from the heaven of S7 to AB
Can't go on-line with a PLC where the code is different, can't compare between off and on-line to see what the differences are, having to upload to be able to get on-line with a client who's a 5 hour flight away, then taking 1.5 hours to upload via the internet...
One of the many things I don't like about AB...
Horses for courses, AB isn't bad at the end of the day, I prefer S7 though.
S7Guy said:That blows my mind. Textiles, due to the intricate weaving patterns, lends itsellf perfectly to motion control. The ones I worked on were replacements of cam-driven machines that were used between the 40's through '95. The new ones had servo controls and vision feedback to keep the patterns perfectly consistent.
dahnuguy said:HEHE..........this is fun...........
Why would you WANT to go online with a code mis match???????
dahnuguy said:The other PLCs wont let you do it either, have to upload and merge symbol file or download.........
dahnuguy said:option A is best so what your looking at is actualy what is happening. I think one of them would allow it though don't member which one maybe a AB5? but it was screwy and not good. Might have even put the CPU in STOP I dont recall.
You CAN compare to see the diffs, I did it many times........but its easier to just upload and merge and get on with it.
dahnuguy said:They could send you a copy through email or post it on a file share server with DSL or highspeed. Of course that would negate their shiney new MODEM though and would "GASP" put their "secret" code on the evil web.
dahnuguy said:I have heard the arguement recently.
1.5 hours while you surf the web or read up on the last version is still better than 10 hours flying plus expenses and time in the plant.
dahnuguy said:I never defend any of them, never have, and I am no expert, but I might be able to help with some AB issues. I would have to go home and dust off the software though. Dont have it all in my head anymore.
