Adding TOD OB
Apr 2004
Ede
19
Hello,
When I started a new program in Step 7, I was asked which OB I want to use for TOD-interrupt. I only chose OB10, but now I want to add some more.
But when I go to HW Config and open the tab "Time-of-day-interrupts", I cannot chose other OB's because they are gray.
With right-click on the CPU in HW Config, I cannot "Open Objects"
How can I activate more TOD OB's?
I'm working offline on Step7 v5.4
I cannot find the answer in the manuals I have.
I hope somebody can help me.
Sorry guys,
I didn't find my answer yet.
What I mean is when I start a new project using the wizard, I can choose to use OB10, OB11, OB12, etc.
But when I allready have a project with only OB10 and I want to use OB11 also, I go to HW Config, rightclick and choose tab "Time of Day interrupt".
There I should activate OB11, but I can't, because it's gray , so not allowed to change.
Can anybody tell my why I can't and how I should activate here?
Can't check properly (at the moment), but my guess is that your CPU only supports one time of day interrupt.
Hello Erik;
Happy Holidays!
There is only OB10 supported as a TOD OB in the S7-300 Compact CPUs. Here is a excerpt from the Compact CPUs Instruction list manual:
If you need more, you will need to roll your own, by reading the Real-Time Clock and using the Date and Time values to setup a trigger for your code. There are SFCs available to help you on this.
Hope this helps,
Daniel Chartier
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
95
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
80
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
151
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
179
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
158
