ADDMX function setup for BMENOS0300 in a M580 Remote drop
xcyong89
Oct 2019
Kuala Lumpur
How is a ADDMX function setup to communicate to slave devices (Modbus TCP/IP) that connected to BMENOS0300 in a M580 Remote drop.
I have search the Q&A in Schneider Electric website. However I did not find any related Q&A on this topic.
BMXNOM0200 is applied for Modbus RTU. From the FAQ, the configuration for is BMXNOM0200 shows as below:
r0.s0.ch0{ip.ip.ip.ip}\\r1.s1.ch1.d
r0.s0.ch0 must be 0.0.3
ip.ip.ip.ip = IP address of BME CRA 31210
r1.s1.ch1 = rack number of BMXNOM0200, slot number of BMXNOM0200 and channel number of BMXNOM0200
d = Modbus ID of slave device in Modbus RTU
However, I did not find any FAQ that related to Modbus TCP/IP that using BMENOS0300 in M580 Remote drop communicate to slave devices
Isn't NOS0300 module switch which is installed to local or remote rack ethernet slots?
Manual have this
NOTE: Use the IP address of the CPU, and not the address of the BMENOS0300 switch, to communicate with the CPU.
So is this meaning that you have to address you master communication same way than your would communicate directly out from CPU's embedded port and Switch (NOS0300) is mirroring all packets that CPU is sending?
Try 0.0.3{target_ip}TCP.MBS??
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
33
1,055
Good morning crew! Ok my logic works but I am missing something. When the start button is pushed it should like the red light for 4sec then shut...
426
Please see attached file. I need this program in Function Block form but I am totally lost on this. Any help would be appreciated. Thanks!
301
The idea here is to provide for a brief rapid influx of message codes while preventing sequentially repeating the same message. i.e. if two...
23
694
