ADFWeb M-Bus converter + Schneider kWh Meter
boneless
Feb 2008
OKC
1,628
Hi all,
I am having trouble communicating with a Schneider kWh module that is fitted with an M-BUS module.
I have successfully used the ADF module to communicate with Kamstrup MC801 energy meters (heating) and Kamstrup kWh meters, but this Schneider module is giving me headaches.
I am receiving data, but I can not make any sense of it. Before I go in deeper, is there anyone that has used similar equipment before?
Thanks guys!
Awesome, I will try to look at the software.
Yes the ADFweb box is my master. It works fairly well, but can be tricky to set up.
Once you get the Schneider where you think that you have it set up, disconnect anything else other than your ADF and the Schneider box and send out the 254 command. At this stage just look to see if you've got blinky lights coming out of the Schneider box, that will pretty much prove that it is at least understanding what is coming in.
52
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
124
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
240
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
176
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
48
