Advantages of Upgrade to DirectSOFT06
twinsemi
Jun 2020
Soquel, CA
Hello world.
This is my first post here.
My question: Should I upgrade from DirectSOFT05 (5.3) to the current version?
My project is to build a PLC system to continuously query our oxygen analyzer to get four digital values over RS-232 and send four channels of 4-20mA out to a customer's safety controller. (F0-04DAH-1 and a D0-006DD)
And I might add that I am a newbie to the PLC world.
Have you thought about using a Click or a Brix PLC for your project? The software if free and these models are way ahead of the old DirectLogics PLC in my opinion.
Look at Host Engineering Web site for direct soft it will tell you whats new in Directsoft 6. I use it daily. Also scroll down and look at version 6 revision history.
Thanks for the feedback. We have decided to go with the Click, for a few different reasons, primarily because it has more usable (ASCII) comm ports than the DL05.
So Ladder is easy to read graphically, most everything can be coded in ladder, and it represents wiring diagrams the closest. SCL and ST are good...
1,742
I need Pros and Cons of WinCC(TIA), WinCC flexible and Intouch,which will be using with Siemens S7 1200 Controller.. It will be used for...
2,309
hey guys, the company I work for has decided they want to update our PLC5 machines to Controllogix with ethernet communication so they can monitor...
2,599
hey guys! i was wondering why did profibus adopted the master-slave exchange of data? it is the most efficient way? For example if i had a...
5,144
what are the advantages for three phase power supply than single phase power supply ?? i have a machine contain electronic cards and three phase...
11,421
