Sure.here is my attempt at a conversion to cscape. any glaring errors that you may notice? thanks
The logic looks ok if you're recreating the aB one.here is my attempt at a conversion to cscape. any glaring errors that you may notice? thanks
One more thing.here is my attempt at a conversion to cscape. any glaring errors that you may notice? thanks
No, a "one-shot" is a bit that causes the rung output to go true (on) for only one scan of the microprocessor. It will not be true again until the preceeding logic goes false, then true again. It is often called a True on Rising Edge, or True on Falling Edge, or One Shot Rising, and so on.Is the "fast scan" the same as a one shot (this was a guess)
I agree with steve.That "FST_SCN" bit is not "Fast Scan". It's "First Scan". It is a one-shot bit that is true during the first scan after you put the PLC into run.
As far as the parallel timers go, I'm not sure. Horner PLCs follow GE Fanuc pretty closely and that rung structure would not be permissible in some GE Fanuc PLCs. If Cscape software has a validation procedure, I'd suggest you run it.
