advise need
ajay34
May 2010
klang
249
hello all...
recently management level inculd my manager had ask me to do a task .
where by currently we have small mixing plant (feedmill) where by using panel mode mean no computer but using man power to handle ..
and now they wanna connect a scada to current plc.so that can be control using computer and recording.
current PLC was using mitshubshi Q series to run mixing .
1) can i use seimens wincc flexiable for recepi and control Q series PLC so that mixing can be done via computer
2) is there any sample of recepi using Wincc felxiable
You could use GTsoft by Mitsubishi to give a computer all the functions of an HMI
https://us.mitsubishielectric.com/fa/en/products/visualization/human-machine-interfaces-hmis-got/gt-softgot
Also you could Use MXsheet software to add all the functionality of Microsoft Exel to the PLC memory.
https://us.mitsubishielectric.com/fa/en/products/controllers/programmable-controllers-melsec/engineering-software#pageUnit4
The recipe stuff could also be done on the PLC then use the above mentioned HMI software to call it from a computer.
What is the model number of the Mitsubishi Q Series do you have?
How do you want to communicate to the PLC? (Modbus TCP / Ethernet)
https://us.mitsubishielectric.com/fa/en/products/controllers/programmable-controllers-melsec/network-related-products/other-networks/modbus/modbus
I have not used it but there is a Wincc Modbus TCP driver.
You could also use a software package like AdvancedHMI.
https://sourceforge.net/projects/advancedhmi/
Hope this helps you out.
Regards,
let me check the PLC model and come back ..i wanted to use direct from pc to PLC via com port (9pin)
thank you for te info ..will look into this as well
THE cpu USING MODEL ARE AS BELOW
QOOCPU.it using direct com rs232.
please advise if i can use wincc flexiable to read all data and send recepi to PLc .currently it using manual method now they wanna go control VIa computer
Hi everyone, I'm having a problems with simatic s7-300 & sinamics s120 system. Some error code are being appeared,Now how can I fix these error...
2,467
Dear Mates, My name is Khan. I am 26 and in the mid age of my career. I am TWinCAT programmer, TWinCAT HMI (local/Web/Handheld) Developer via...
5,296
Hi experts; I use 90-30 series PLC and CPU352. I want following please advise how i can implement this? I have a Setpoint which store in a %R1...
1,527
Hi friends; I am working in oil and gas department. The control is build in relay logic and works fine. The pressures tepmratures and frequency...
1,556
I know virtually nothing about PLC. Some VBA experience. My project, using a simple analogy, is to make a programmable door bell ringer. I want...
4,435
