LOL you guys are really funny. I dont know much about them they were installed already. I just ran the lines to them as instructed. I will find out. They are not horns. They are vortexes
Yeah, silly me...shoulda thunk-it wuz whacha meant
I actually have heard them sound like horns...
You want the vortex coolers (typically around 12SCFM) to have a high flow regulator, and likely a temp controlled valve rated for that.
CFM is gallons per minute for air.
If you're filling your swimming pool from 40psi (pressure, force, power) with a 3/4" hose and it's half way full, what do you think switching the hose to a 1/2" would make the 2nd half fill up faster or slower than the first?
I thought you might be setting up an alarm horn (intermittent), so forget using a 2" air hose for an accumulator.
The vortex is going to fire up for minutes at a time.
Also, be extremely sure the dicharge (slow cold air) tube inside the panel is both secure and routed to a drain...
Somewhere, some way, water will get blasted into your plant supply, and I have a dead 1756-PA2 to prove it.
They are gas hogs (vortex air horn coolers). Hugely expensive to operate, itty bitty living space...
Don't connect them straight to your mains without at least a regulator/solnoid, but I also recommend a local FLR or tap off of one and resize it for the added load, which is pretty huge. Think of someone running three or four air ratchets off of each of those regulators...
I also recommend that you get the right flow rated regulator and use a demand switch/thermostat of some sort.
The one that blew snot inside a logix PLC was not tied well enough inside, and something caused 100psi air/water sneeze to go into the panel! This was where a local FLR (also relative big-asz to meet SCFM of 12-14!) would have saved us but it was not properly maintained. Secure that hose to the inside as if you expect it to withstand your plant supply pressure. And, tie down the inside hose expecting somehow, someway, nasty plant air to get through the thing.
