leitmotif
willie said:Hello all;
I am trying to design a pressure tester with RSLogix 500 to detect a air pressure leak in metal tubing. The leak rate cannot be more than 100th of a psi per 4 seconds at a pressured chamber of 60, 40 and 100psi.
Willie
0.01 psi per 40 = 2.5 e-3 or .025%
.01 psi per 100 = 1 e-4 or .001%
Sure sounds like a tight (too tight ??) tolerance to me. I recognize they want to do the test quickly especially if testing each and every unit which is why the 4 second criteria.
What are you building these for
-- DOD nuclear weapons
-- biohazard labs?
Instead of measuring pressure drop can you change the spec to flow ie a leakrate of .1ml per minute or second etc at X,Y and Z pressure? This way you can use a flow meter both visual and electronic if you wish.
Dan Bentler
