Allen Braddle SLC500 SLC5/04 1746-NO8I
Rashid, more threads of the same thing doesn't speed up the response.
The advantage of having a thread title that describes the issue, is that it can then be searched by someone and possible answer there issue without having to wait for a response.
Your problem of no 8 channel AO being available and having to use 2 x 4 channel is just a change in the code hopefully (as long as you have a spare slots in the rake).
You will need to separate the channels from the old 8 and reassign the outputs to the different slots where you have installed the new cards.
So should be just reassigning the addresses in the code you already have for the AO to match the new card location.
im using Slc5/04 one of its 8 channel analog output module 1746-NO8I got defective if i replace it with new one do i have to re-program or...
3,277
i have 2 backups: *.PVC and *.pvd file types thanks in advance for any help
95
402
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
110
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
19
762
