allen bradley 1785-L60L/E
plctech187
Dec 2007
nc
i have a allen bradley 1785-L60L/E and i can't find the cable for channel 2 the manual says its a 50 pin dedicated extended-local I/O port but i can't find a part number to this cable, Does anyone know the part number for this cable?
thank you
According to User Manual 1785-6.5.12, you need 1771-CXx, the last x being 1,2, or 5 for distance in meters.
Also read chapter 8 which covers exntend local IO.
We have many sites with PLC-5s and 1785-ENET sidecars that are being pounded pretty hard by the GE IGS driver (Kepware) and iFIX/Historian...
990
Hi , anyone knows what is the alternative of the back-up module 1785-bcm(allen bradley) ?
1,653
I have a 1785-l40E/E that I am having a weird problem with. I am not sure if the processor is bad or if it is another issue. The problem is the...
2,428
Can someone provide me an example of message configuration from Allen-Bradley PLC-5 to an Omni 3000/6000 Flow computer through the 1785-KE module?
3,995
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
35
