Allen bradley activation hosting
Fanuc_Bradley
Mar 2017
quebec
I have all my activation for all my Allen Bradley software linked to my HDD serial number, I was wondering if I lost my laptop or my HDD broke how can I get my licences?
I've tried to get the licences from another laptop while they still on my laptop and can't find them. I have to rehost them before they will be available.
thanks for help 🤞🏻
If you look in the factorytalk activation manager it shows you where your .LIC files are. You can back these up. Of course if your hdd blows up your new one won't have the same number.
If you have the original certificate that came with your software then you can call up tech support for assistance.
I would suggest that you Rehost your Activations and use a USB Dongle as the Host ID, rather than the current Hard Drive Serial Number Host ID. The USB Dongle is portable and also gives you the option of storing the license files on the Dongle itself. Keep the Dongle safe and away from the laptop workstation when not in use.
You can also install the same software products on another workstation, or multiple workstations, using the same software serial numbers. Just plug the USB Dongle in to whichever workstation and it will Activate the software products. Once Activated, you can plug out the Dongle, or be using it elsewhere, and the software products will remain Activated for 7 days under the Grace Period.
If your laptop goes missing or the Hard Drive fails, and you have the USB Dongle safe, then you can simply install the same software products on a new workstation and just plug the Dongle in. The software products will be immediately Activated. No need to Rehost or contact Rockwell.
Some previous info...
http://www.plctalk.net/qanda/showpost.php?p=659430&postcount=6
Regards,
George
.... Once Activated, you can plug out the Dongle, or be using it elsewhere, and the software products will remain Activated for 7 days under the Grace Period.
George
I have never tried that, and it would be a great advantage in many situations... I'm always concerned about that great big green thing sticking out of the side of my laptop, it's already taken a knock or two, and does look a bit "bent"... plus I'm concerned about possible damage to my laptop USB port. Is the 7-day grace period cumulative ?
.... or be using it elsewhere .....
I am sure you meant to say "be using it to activate a different software product on another machine".... using the dongle to activate the same product on multiple machines would not be allowed under the license agreement, unless, of course, the license is valid for multiple "seats".
@daba I use a short (literally, 6 inch) USB extension cable for the dongle for exactly the reason you are concerned about it. Haven't had any issues yet.
Rockwell is really good about providing a new activation, I've had to do it 3 times with my personal RS500.
1st I had it on a HDD, that died. Rockwell said to tag it to my NIC card, so I did. Puter got killed at a factory so I got another one. Very painless working with Rockwell tech.
We have all of our other activation's on that ugly green USB dongle. I too worry about that getting broken. So, after I open the software once it's activated for that session, I unplug it and put in pocket. Works well that way. I like the short USB cable idea tho.
Just an observational side note on using some versions of 5000 during the grace period. The software may not be fully functional during this period. I've only tried it a few times and V20 would not allow me to do online edits. V29 seemed to go into service mode after a day. No edits offline or online. Don't leave home without your dongle!
Agree with jstolaruk, I found the best way is to host all of our licenses on a computer or server, then borrow when need. But this only works if you licenses are concurrent licenses.
Example I currently store our licenses on our AssetCentre server and I have installed controlled wireless AP in the facility on the controls newtwork.
So all I do is open which ever AB program I need to and as long I'm connected to the network FactoryTalk activation manger auto borrow license that is needed.
Why not just get a Activation Dongle from AB then it doesn't mater what computer you are using the activation are on the Dongle.
if you are like me I keep a copy of the software I download so I can reinstall if my computer fails.
you will also need a copy of the Certificate's with the activations.
I moved copy of them on the Dongle for safe keeping
I like putting the activations on a office computer and then borrowing the activation to my laptop once every couple of weeks.
Yes, that is what we do. Don't have to worry about misplacing our server in the boss's office. I often let a license borrow term expire and run on the grace period for a day or two. Takes less than one second to click "Ok" for the warning a couple of times a day.
Once in a great while one of us has to use the VPN to borrow a specific license from a distant hotel room. Sometimes over the VPN, you have to hit refresh activations a few times to get them to show up, but I think that our solution is much simpler and certainly easier to keep up with than a handful of dongles since there are now five of us who use various Rockwell software products.
I spoke to a couple guys from the activation's team at RS Tech Ed about this but I can't understand why they don't use a better dongle. The current dongle is an improvement over the origianl because the original had no storage for yor .lic files.
I wish they would use something like the Sandisk I have in the pictures. It's small enough not to get hit or damaged while in your laptop and could be activation and storage (this one is 32 GB)
I am planning on getting a new maintenance laptop and want to keep my old one for a spare. I guess I will need to put my activations on a dongle...
1,824
I recently purchased Allen Bradley RSLinx single node software. When I received it, I did not find a master disk I was used to but found a...
18
10,089
Some how I lost my activation file in my laptop. I have no idea how to find this. I recently upgraded my OS from windows 98se to XP. (I moved...
28,137
369
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
93
