Allen Bradley Analog Scaling
irondesk40
Jan 2008
nc
630
If using a ab analog module do you set it up to use the raw value or do you set it up to scaling for PID?
I have always used the raw value. Not that I think it is the best way, but it was basically the only way I knew you could do it the first time I had a ab project throwed at me to control a autoclave machine and had never used a ab plc at that time.
It always helps to list the exact PLC Model and Version, and the Catalog Number and Version of the Analog Card you are using.
Using PID Scaling saves you a Scaling Step, if you are using the Analog Input for a PID Instruction. Some Cards have up to four choices for Scaling.
Stu.....
Hey Folks. I know its the same old struggle, but I need to get Analog Inputs into an AB system without any Analog Input Cards. Initially I...
5,528
Hello to all. I am new to PLC’s as well as this forum so if I make any mistakes please forgive me. I am having an issue using the 2080 OF2...
2,811
Hi, I'm curious if anyone has made a master sheet or cheat sheet for all allen bradley card's analog inputs/outputs? As much fun as it is to...
1,597
This hasn't become my problem yet, but it may soon... Ancient PLC-3 (yeah, I know) has been humming along for decades. It now has some analog...
2,467
Hello all. I have been working with an SLC 5/04 system, which houses various Digital and Analog INs and OUTs, up to Slot 29. I am currently...
2,531
