Allen Bradley Compact I/O Expansion Cable damaged
randomhero_87
Mar 2023
KY
We have an AB PLC that has a faulty expansion cable between Bank 1 and Bank 2. Part # 1769-CRR3. I found a small burn mark on the board. Being that this is communication only, should I look for a power issue elsewhere? Any input would be greatly appreciated.
Thanks,
Justin
It is difficult to see from that photo what may have caused it, but looking at it the burn seems to be on what could be possibly a power rail, notice the outer one with the burn is smaller than the inner one round the connector, it is more likely if this is a power rail then something close to it has touched it or perhaps water ingress or a foreign object like a cable clipping has made it's way into the system, have seen where during the panel build a small strand of cable must have been stuck either in the trunking or under a component & after a time worked loose & fall either in some electronics like the PLC or contactor etc.
I was wanting to see if anyone had any information on setting up a cub5 meter and getting the data to a Allen bradley PLC. I think i have the set...
139
Hello everyone I have an Allen Bradley Compact Logix 1769-L18ER-BB1B. I have several processes that I would like to start based on time of day...
2,688
I have two L35e processors i want to send message to and from. I just want to do data read. Condition from one plc and see it on another plc. I...
2,226
Above mentioned HMI is installed in my plant with Micrologix PLC. Yesterday the HMI suddenly stopped working during plant operation and HMI's...
4,940
Here we have a machine that is running with AB LM35 compact logix PLC communicating the SEImens micro master 430 drives using profibus protocol.As...
2,066
