Allen-Bradley CompactLogix w/ B&R X20 I/O - Tutorial
That's the slickest third-party I/O Logix integration I have ever witnessed...Thanks Shawn...(y)
One question might arise though...Can you do Produce/Consume (or something similar) between a Logix controller and a (ABB) B&R X20 CPU?...Couldn't help noticing that the Backplane concept has migrated to Austria several years ago...And now they're counting the revenue in ZĂĽrich...:D
Good question, I can test this out -- but I believe ABB&R CPU would connect via E/IP and you could use Generic CIP Messaging between the two.
Shawn, any EIP communication capable processor could Explicit Message data to/from any similar devices; but this is programmaticaly implemented.
Produce/Consume Logix CPUs expose their tags and I/O to each other implicitly without the need of coding; it is a cyclic (I/O Class) high speed data transfer not related to any user implemented logic.
It could be similar to the way you have added the B&R EIP Scanner and the associated I/O to the RSL5K application I/O tree via the compiled .L5K B&R Export application you used to create the CompactLogix one.
oops, I overlooked the produce/consume part.
When I try to add the E/IP scanner to a project with an existing B&R CPU it will error out "cannot add second CPU" - so in that manner I would say it's not possible.
Good afternoon, I'm building a test station for temperature mapping that will log 12 data points to SQL via Open Automation Software. This station...
1,969
Hello everyone, It's been a while I haven't dive into PLC programming (more than 5 years) and I wasn't doing it alot as programmer. I am now...
1,842
Hi, this is my very first thread. I am a PLC enthusiest and am setting up an AB compactlogix 1769-L35E controller with some relays at home to play...
3,093
Hello. I am new to the world of PLC's. We just bought a Compactlogix L24ER QB1B and I am now trying to connect to RSLinx. However, the program...
2,392
I thought I could learn PLC ladder logic better if I had a Controller. Think again! My PLC knowledgeable co-workers tell me basic setup is Level...
3,694
