Allen Bradley COP slc function help
veoteveo
May 2008
Mexico
20
Hello,
I need to copy values from one location to another.
example N10:0 (N10:1, N10:2...etc) to N10:10 COPY to
N11:0 (N11:1, N11:2...etc) to N11:10.
the values in each N address are unsigned intergers, either 1 or 5 intergers.
How do I use the lenght function?
thanks
Important:
Length = number of contiguous elements you want to copy.
When both the source and destination are Integer words, then the number of elements is the number of words.
But if either the source or the destination is a different data type, the number of elements of the destination determines how much data is transferred by the COP instruction.
For example: if the source was an Integer and the Destination was a Floating Point element, the COP instruction would take two integers from the source for every one Floating Point element in the destination.
This is more important in RSLogix 5000 than RSLogix 500, but it's still worth being specific.
In your case, veoteveo, the Length argument is the number of elements = the number of integer words.
While doug2 is correct in this case the length is actually in terms of the target items. If you are copying unlike things ,let's say N registers to Timers, then the length would be in terms of how many timers, each taking 3 words. Yes, it is possible to copy a whole timer.
Ken you're just too fast.
Hello all. I have been working with an SLC 5/04 system, which houses various Digital and Analog INs and OUTs, up to Slot 29. I am currently...
2,551
Hello, I need to copy values from one location to another. example N10:0 (N10:1, N10:2...etc) to N10:10 COPY to N11:0 (N11:1, N11:2...etc) to...
2,592
Any one give solution for this fault. We are using AB Gaurd logix controller(5573s), resent days we are facing major fault in controller...
66
Hi how's it going. Was just wondering if someone could help me out. Recently one of the guys over on the LinuxCNC forums put me onto getting an...
341
Hello, Does anyone have one of these cables and willing to open the case so I can see the cable connections inside? 2707-NC5 I have sourced the...
100
