Allen Bradley EvMoveCF.exe does not work in Windows XP Mode
epicnote
Feb 2011
Malaysia
45
I am having a problem to move master license from USB pendrive E: drive to C using EvMoveCF.exe in Windows Virtual PC XP Mode. In EvMoveCF drop down list, there are only drive A,C and D. I cannot see the E drive. Anyone know how to fix this?
Thanks in advance
Thanks for the reply anyway. Yes, i can see my pendrive in both OS whether in Windows 7 or Windows Virtual XP Mode. Only when I open EvMoveCF.exe, there is no pendrive listed in dropdown menu.
If I remember right, one of my customers moved it first from usb flash drive to actual host OS drive. He then mapped that drive inside guest OS and used standard EVMOVE (from inside XP Mode) to move from host drive (which shows up as network drive) to Windows XP Mode drive.
Darren
I know it work correctly in VMWare. Before I used VMware, I used XP mode briefly. I don't remember any issues in transferring the file using EvMoveCF as long as the flash drive was recognized by the OS.
That should be EVmoveCF. The CF stands for compactflash.
Yeah... I have two versions, EvMove and EvMoveW. I remember the CF. The W version if IRC, is for Windows. I only have the two installed.
Maybe I'm having a memory failure, lol.
ETA, I did find the Cf version, guess Ihad it in a diferent area. OOps.
Hi how's it going. Was just wondering if someone could help me out. Recently one of the guys over on the LinuxCNC forums put me onto getting an...
229
Hello, Does anyone have one of these cables and willing to open the case so I can see the cable connections inside? 2707-NC5 I have sourced the...
84
Currently trying to find: micrologix ethernet interface 1761-NET-ENI AIC to micrologix 761-CBL-AM00 Ser C cable These are used for micrologix...
133
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
173
459
