Allen Bradley Explicit Messaging
kentrols
Aug 2004
I am trying to use the new DEM explicit messaging instruction in RSLogix 500. I am using V7.10 software and the SLC L552 is flashed to OS501 Series C FRN 10 and later. However once I have entered a rung with the DEM instruction the RSLogix screen updating slows terribly. A cross reference takes minutes. I have tried it on a few different PLC's with the same result. Can anyone offer any suggestions as to what I am doing wrong?
I have not experienced any sort of RSLogix slowdown related to using the DEM instruction.
Is this a DEM instruction that you are continuously triggering ? Any access to the M-files of a 1747-SDN will slow the processor scan a little. Try disabling the message and see if the slowdown is related to the message being present, or the message executing.
I will be back on site tomorrow and will try a few different program schemes. However, I am not so much seeing long processor scan times, just really slow programming access. For example, I did a cross reference on the data table I am using in the DEM instruction and it took over five minutes to complete. During this time, RSLogix was completely locked up.
Followup
I have again tried the DEM instruction and am experiencing the same slowdowns as before. Even when the instruction is not updating, just having the DEM instruction compiled in a rung causes RSLogix to slow to a crawl. Has anyone else experienced this?
I have the same issue. I have 2 DEM instructions and am trying to use theGet Pareameters Scattered DPI object, but cannot find any example (hint, hint)
The problem, this is a guess and test thing for me and with the udate this slow the programming is terrible!
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
37
408
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
110
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
19
768
Hello, I am new here. I am trying to find good places to sell some surplus items that I have that isnt through ebay. Does anyone have any sources...
462
