allen-bradley L552/C rs232 won't connect
rudydeez
Apr 2015
corona
Hello,
I'm not very experienced with plc's. Starting out.
Is there a way to connect with Ethernet without using rs232. Unkown ip address. I can't go online with rs232. My other plc works fine. So I guess sothing wrong with the port.
Thank you
You can in fact connect via RS232 in order to configure and/or determine the IP address of the controller. Assuming that the serial port of the SLC is at it's default configuration of DF1. You must use what is called a Null Modem cable like the 1747-CP3 or 1756-CP3.
Can you share some information about what you have to work with here? RSLinx version, cables/adapters you have, operating system?
edit: When you say that your other PLC works fine, does that mean that you can connect fine over the RS232 port?
Currently trying to find: micrologix ethernet interface 1761-NET-ENI AIC to micrologix 761-CBL-AM00 Ser C cable These are used for micrologix...
56
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
160
446
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
115
23
1,015
