Allen-Bradley RSLogix5000 - timer question
Jul 2008
NL
19
When implementing a timer, when I go to enter a value for the preset, it states that the ladder element field is non-editable.
I was wondering if anybody has any insight into fixing this problem?
In RSL5000, the timer nor its elements exist until you create the location. You can't assign a "preset" to a non-existent location. Different than the other RSL products, but that's the way it works.
This is the way it is, Tom is right.
Create a new tag, "My_Timer" or something similar,the data type of the tag defined as "TIMER".
Once your tage is created and defined you can enter parameters as you would like.
I'd suggest that you create the tag under "Controller" in case you need to monitor/edit from an HMI.
Hello Everyone, I had a doubt in reading expressions written in structured text in format c := a and b. Where a is a DINT and b is a constant...
1,186
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
34
407
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
110
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
19
764
