Allen Bradley SLC500 and CDN066 with RSlogix500 or RSnetworkx?
Buscom
Jul 2013
paris
78
Hello,
Please I need help 🤞🏻,
I would like to establish the sending and reception of data between SLC500 Allen Bradley and DSP Texas Instruments.
DSP is on serial port and I use a CDN066 to convert RS232(serial port) to DeviceNet (1747SDN DeviceNet port).
I want to know if for the programmation of the SLC500 to send messages to the DSP through CDN066, would I need RSLogix500 or RSNetworkx to program?
Indeed, what is the use of RSNetworks?
Please, do you think that I will also need the 1770 KFD??
Because, I have read in the datasheet of cdn066 that I will need the 1770KFD for Allen Bradley to connect RSNetworxs to DeviceNet.
But me, I don't want to communicate in DeviceNet between the SLC500 and my PC. I just need my PC to programm the PC througt a serial port or a DH485 port and not to communicate in DeviceNet.
The DeviceNet communication is only between the SLC500 PLC and the DSP oof texas instrument and I have the CDN066 to make conversion from DeviceNet to RS232 (DSP¨port)
Do you think that I need also 1770 KFD???
Please, need help.
Thanks.
According to http://www.mksinst.com/Docs/R/dipcdn06xman.pdf
you will need to configure the DeviceNet network Master, its Scanlist and the type of data packets transfer.
For DeviceNet on SLC platforms, the only way you could accomplish this task is via RSNetWorx for DeviceNet while connected to the network using a PC to DeviceNet interface, either Serial RS232(1770-KFD) or USB(1784-U2DN).
http://literature.rockwellautomation.com/idc/groups/literature/documents/in/1770-in006_-en-p.pdf
http://literature.rockwellautomation.com/idc/groups/literature/documents/in/1784-in046_-en-p.pdf
HI, I'm currently also trying to get an Allen Bradley SLC500 fixed. Our technician is trying to replace all the Takamisawa JY25H-K-505 relays. So...
1,765
I have 2 identical systems that have the AB SLC500 Basic card in them. I system stopped working and the issue was traced back to the card...
3,047
HI, My first post on here, Using SLC500 I have a STRING LEN 30 that I need to convert just the first 2 characters (POS 0 , 1) into an INT. any...
2,439
I have two output cards sitting next to each other in a rack: 1746-OW16 1746-OW16 (Octal) output 13 in the first card triggers a solenoid. When...
2,207
I propose to replace an old pc with the latest HMI from Schneider running Vijeo designer. Firstly, am I correct in thinking that I can use RS500...
3,047
