Allen Bradley structured text string comparison
waker1der
Aug 2015
Watford
Hi, i am trying to compare a string value in an IF statement
My string value is user defined string called Barcode_String max characters 26. This can not be changed as it is used across the plant.
I pass that barcode string in to my AOI to a parameter called inBarcodeID which is of the same data type.
i want to know if there was a no read and in this case the value would be 00000000
IF inBarcodeID = 00000000 THEN
or
IF inBarcodeID = '00000000' THEN
does not work because of mixing data types, it wont compile.
so I have tried
IF inBarcodeID.DATA[0] = 0 THEN
noRead := 1;
END_IF;
but noRead does not change, i also tried
CASE inBarcodeID.DATA[0] OF
0 : noRead := 1;
END_CASE;
but this also doesn't change, has anyone got experience with trying to do comparisons like this?
Try defining another string, and using it as a constant to compare to.
That is, make another string tag of your Short String type, and manually set it to "00000000"
I may be incorrect, but this is the way Rockwell have decided that string comparisons must be done. It is also the same in RS500.
The potential downside is that the source string can be modified..
I read that as of version 30 and the L8x controllers you can have literal strings in assignments and comparisons.
http://literature.rockwellautomation.com/idc/groups/literature/documents/rm/1756-rm003_-en-p.pdf (page 827 and 828).
Regardless of that, try to inspect the barcode tag itself you receive into the AOI. Altought is may look like as 000000000 in the tag monitor, the .DATA[0] may not contain 0 because it holds the decimal ASCII value of "0", which is 48.
Default the style is set to ASCII, but the logix program uses the DECIMAL value in the logic.
Hello Everyone, I had a doubt in reading expressions written in structured text in format c := a and b. Where a is a DINT and b is a constant...
1,184
376
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
94
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
19
728
Hello, I am new here. I am trying to find good places to sell some surplus items that I have that isnt through ebay. Does anyone have any sources...
452
