Allen Bradley to PC comms
taward31
Nov 2012
Dublin
51
Hi All,
Have an upcoming project and will want to some how trigger an PC .exe file to run a download into a device.
The trigger will preferably need to come from an Allen Bradley PLC Logix 5000 ( any type )
Anyone done this before any ideas of software etc that would help ?
Thanks in Advance!
You could use an Arduino Leonardo plugged into a computer USB triggered by anything that turns on one of its inputs. It can function as a keyboard and send key sequences such as a combo to trigger a macro, or you could probably populate and enter a command line. Other Arduino models can do this with a different boot loader, but the Leonardo is ready out of the box.
Hi All,
Thanks in Advance!
Try Archie's AdvancedHMI if you can talk to the PLC from your PC via Ethernet.
https://www.advancedhmi.com/
I am having trouble with communication between my micrologix 1000 and my magelis HMIGTO5310 touchscreen i have added the allen bradley df1 driver...
1,485
Hello all, I joined this forum because I saw there was discussion about the 8 Pin Mini DIN connector on Allen Bradley. I am trying to connect...
18
9,905
Good day folks, having some trouble with a PLC here at work. I have an Allen Bradley SLC 5/03 controlling a palletizer and I need to make some...
3,462
Anyone have any code or suggestions as to how to get reliable comms between an Bristol Control Wave PLC and a ControlLogix series PLC?
2,225
I'm wondering if I can get a MicroLogix or Micro800 to communicate with another same CPU over a dedicated phone line, using dial-up modems? I've...
1,554
