Allen Bradley Ultra 3000
Lawrie
May 2011
Smithfield, NSW
G'day Fellows,
I have an Allen Bradley "Ultra 3000" digital servo driver. I'm not experienced in these things, While I know a servo motor is like a stepper motor, These drives sound like they will do anything. Can I run a conventional 3-phase with one?
regards,
Lawrie
no... you have to have the right servo-motor for the drive.... If you have all the data on a motor and you have the time and experienced maybe you could get i to work but....
Ultra 3000
Thanks for the info, I had thought that probably would be the case.
The other type of motor I have is in a small A/C compressor. This motor is a "switched DC reluctance motor" I'm told it is a design related to stepper motors. It has 3 connections outside the compressor and tests like a conventional 3-phase star-wound motor. I was wondering if the Ultra 3000 would be capable of running that??
regards,
Lawrie
My answer will be the same....
The ultra 3000 is for servo motors.
A servo and a stepmotor is NOT the same...
Is there a good reason, to connect a deferent motor to this drive?
Hello everyone. I am working on a rebuilt AB-Ultra series drive (1998) and the firmware for the drive is needed to test and use the drive. I would...
462
Needing RS Logix 5 programming examples for communicating (PLC 5/40E) to multiple Ultra 100 servo drives over devicenet. The user manual for the...
1,313
servo sürücüm var. kodu: 1398-pdm-030, lütfen çok acil bir programa ihtiyacım var
3,930
i have servo drive. code : 1398-pdm-030 , I need a very urgent program please
1,408
Hello everybody, need your help, I have old piece of equipment with Ultra 100 drive, and have one spare drive on shelf. I want to program spare...
4,293
