Allen Bradley
If you mean to ask if you can go online with RSLogix to program the PLC using a serial cable, then the answer is yes. You have to set up a DF1 connection in RSLinx.
The cable you need is a standard null-modem cable (connect pins 2-3, 3-2, 5-5).
If you mean to ask if you can send programming commands via ASCII, then the answer is no.
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
147
421
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
113
19
792
Hello, I am new here. I am trying to find good places to sell some surplus items that I have that isnt through ebay. Does anyone have any sources...
478
