Allen Bradly PLC 2 Program Error
riyajahamad
Jun 2002
Pune-India
133
Hi, we have Allen Bradly PLC 2 which control 2 SPM ( I mean two I/O rack )When we start (control on) one of SPM, PLC shows Program Error. My question is :
Is it software problem or Hardware ?
How to solve the same as we don't have the communication software and cable.
Thanks in advance.
As far as I know you need to get online with the processor.
Seeing as how the software is so expensive ( TOPDOC is $3,750 USD and AB 6200 is $9800 USD ) it may be cheaper to call in tech support from Rockwell. Unless you can find a contractor local that has it.
You may want to consider a processor upgrade too. AB may still support the processor upgrade program they had for PLC2 to PLC5s for a discount.
AB does indeed sutpport an upgrade program. You have to work with your Rockwell rep. Basically you will end up sending a copy of your PLC program to RA, and they will crank it through a translator that they have. Then you replace the PLC/2 with a PLC/5, load the program and you're up and running. Rockwell will buy the PLC/2 back from you, dont expect a lot of money for it, but they do buy them back and refurbish them because there are people who do not want to upgrade, though I can't imagine why they wouldn't.
Anyone know what these statistics mean or if there is a page that explains it more? I couldn't find anything on Rockwell's website or literature...
63
Hello all, I have an Allen Bradly Logix 5561 which talks to an ethernet card then to a DeviceNet 1756 DNB card which then communicates to several...
24
7,094
Hello All, new to this board and especially to AB plc's. I was checking to verify the items on the Device Net by using the node...
1,200
So i am looking to install a small AB system to control a unit in my plant and i need to talk with my GE 90/70 (main machine PLC) as simply as...
2,417
Dear Sir, I want to convert my Allen Bradly Ladder logic into Mitshubishi GX Developer, is there any particular software for this or...
2,331
